Black gap problem
Black gap problem
Jackie Teh
3ds max design 2023, V-Ray 7 [7.00.03 build 32836]
AMD Threadripper 1950X @3.40 GHz | 64GB RAM | Nvidia RTX 3070 ti
Website: https://www.sporadicstudio.com
Email: info@sporadicstudio.com
YouTube: https://www.youtube.com/c/SporadicStudioTags: None
Originally posted by Zdravko.Keremidchiev View PostWould it be possible to send the scene to support at chaosgroup.com so we could investigate further? When you do please make sure to mention this thread and the V-Ray version that you are using.Best regards,
Jackie Teh
You can look for smoothing group issues, coplanar faces - the usual suspects when dealing with booleans. Could also be a GI issue when you're using low IR settings.Software:
Windows 7 Ultimate x64 SP1
3ds Max 2016 SP4
V-Ray Adv 3.60.04
Hardware:
Intel Core i7-4930K @ 3.40 GHz
NVIDIA GeForce GTX 780 (4096MB RAM)
64GB RAM
DxDiag
Originally posted by Art48 View PostYou can look for smoothing group issues, coplanar faces - the usual suspects when dealing with booleans. Could also be a GI issue when you're using low IR settings.
Originally posted by Morne View Post1st thing to do after a boolean is check the smoothing groupsBest regards,
Jackie Teh
Originally posted by Zdravko.Keremidchiev View PostWhen you get to it please send it over. It will be difficult to troubleshoot the issue without it.Best regards,
Jackie Teh
You render with IrrMap ? if so, I'd go for unsufficient IrrMap sampling. In such cases, I usually uncheck Use IrrMap option in the problematic objects' material settings.Nicolas Caplat
www.intangibles.fr
Originally posted by NicoC View PostYou render with IrrMap ? if so, I'd go for unsufficient IrrMap sampling. In such cases, I usually uncheck Use IrrMap option in the problematic objects' material settings.
my staff have deleted the max file, i cannot try it nowBest regards,
Jackie Teh
