Black gap problem
  • Black gap problem
    Hi, i have some black gap problem as shown in the attached image, i built the model using ProBoolean method, i have try excluded the object from my vraylight but still the same.
    someone please help me out, thank you.
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
    Would it be possible to send the scene to support at chaosgroup.com so we could investigate further? When you do please make sure to mention this thread and the V-Ray version that you are using.
      Sorry, the file is not with me now
      Jackie Teh
        When you get to it please send it over. It will be difficult to troubleshoot the issue without it.
          You can look for smoothing group issues, coplanar faces - the usual suspects when dealing with booleans. Could also be a GI issue when you're using low IR settings.
          Software:
          Windows 7 Ultimate x64 SP1
          3ds Max 2016 SP4
          V-Ray Adv 3.60.04
          Hardware:
          64GB RAM
          DxDiag
            1st thing to do after a boolean is check the smoothing groups
            Kind Regards,
            Morne
              i have apply the smooth modifier to the problem object, but still the same. (i have weld all vertice before apply smooth modifier.)
              actually i didn't use boolean in this case, i just import the sketchup file given by my client into 3ds max.
              Jackie Teh
                I have to apologize to you, the file have been delete by my staff
                Jackie Teh
                  You render with IrrMap ? if so, I'd go for unsufficient IrrMap sampling. In such cases, I usually uncheck Use IrrMap option in the problematic objects' material settings.
                  Nicolas Caplat
                  www.intangibles.fr
                    Thank you very much for your reply. i will note down and promise to give a try next time when i facing the same problem.
                    my staff have deleted the max file, i cannot try it now
                    Jackie Teh
