progressive not timing out
  • progressive not timing out
    hi,
    i`m trying to render a large 30000 pixel image with progressive and even though i set a limit of 15 mins to render it doesn`t quit. it hasn`t gone past pass 0 yet so i`m wondering if another end condition is now taking priority ?
    obviously 15 mins isn`t going to be enough time to render this image but i just thought it odd it hasn`t quit yet, it`s now at 23mins but still estimating 15 mins. my pc has only 32gb and it seems like it`s using a lot more memory than that. i can see the image updating although painfully slowly, i presume it`s because it`s paging to the hd a lot.
    in bucket mode there`s no problem and it`s only using 9gb of memory to render. should progressive use that much more ? it`s not a big scene at all just some curvy cylinders.
    BF/LC 3.40.03
    thanks
    anthonyh
    edit: figured out the memory use might be down to rendering the whole image at once ?
    I think it needs to make at least one image pass before it can stop?
    What on earth do you need a 30,000 pixel rendering for!?
    Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
    www.robertslimbrick.com
    Cache nothing. Brute force everything.
      1 pass min, that would explain it.
      it`s a big poster for a show. technically they probably don`t need it that big (imo) but clients get it in their head it has to be the best quality it can be, that is before their print guys probably can`t handle it and downsize it without telling anyone. happens quite often.
      anthonyh
        I'd render out at half that (still way more than high enough res for a billboard!) and then if the client kicks off about it, upscale it in photoshop. Guarantee they won't tell the difference.
          you`re probably right. if by some miracle they do tell the difference i can say it was a render error or something. hehe
          thanks
          anthonyh
            Hello!
            We have a help page about rendering large resolution images. Check it out: https://docs.chaosgroup.com/display/...y+Large+Images
            Margarita
            Margarita Stoeva | chaos.com
            Chaos QA (V-Ray for 3ds Max)
              hi,
              thanks Margarita, looks very useful. i`ll give that a whirl.
              thanks
              anthonyh
