I'm having trouble with the denoiser element in Max 2015 ver 3.5.04. I receive the warning "Noise levels render element not found". single pass on rgb, show noise result channel. The denoiser pass completes but no result is visible in the denoiser channel. Very simple test scene with sphere plane and sun.
3.5.04 Denoiser error
This sounds very strange. Are you sure V-Ray is installed properly? Any other third party plugins that can cause troubles?
If it crashes with basic scene like that it could problem with the setup. Best would be to send mail with link to this thread to support@chaosgroup.com. They can track it or if anything else doesn't help, offer remote session to check what is going on.
Best,
Blago.V-Ray fan.
Looking busy around GPUs ...
RTX ON
I Use the default installation setup. All the paths look okay. It's very odd that it works if I go back to 3.4.01. It was all working fine with 3.5.04 until I noticed that the denoiser wan't working. It was after switching to different versions for testing that the Max crashes started happening occasionally. It got worse and worse. I went through the max install folder to make sure all the files were gone before reinstalling.
Originally posted by arobbert View PostI Use the default installation setup. All the paths look okay. It's very odd that it works if I go back to 3.4.01. It was all working fine with 3.5.04 until I noticed that the denoiser wan't working. It was after switching to different versions for testing that the Max crashes started happening occasionally. It got worse and worse. I went through the max install folder to make sure all the files were gone before reinstalling.
Best,
Blago.V-Ray fan.
RTX ON
When Max crashes like this - it creates a crash dump file called 3dsmax_minidump.dmp located in the temp folder (%temp% in windows explorer). If you could send one such file to the support e-mail it might help diagnose the problem.
YavorYavor Rubenov
V-Ray for 3ds Max developer
Created a new test scene. Not crashing anymore but the denoiser isn't working.
I receive the warning "Noise levels render element not found". selected single pass on rgb, show noise result channel. The denoiser pass completes but no result is visible in the denoiser channel.
