Here is a problem I have some difficulties to identify.
When using V-Ray VFB, while rendering, if we touch some settings like white balance, max hangs, change active windows with each it can find (render setting, main ui, vfb etc) and no change can be seen. I doesn't crash but can tak minutes to come back responsive.
Sometimes, even zooming in vfb with mouse wheel cause white vfb and takes age to come back, if it does. Same on some render slaves via BB, the rendering finish fine but the vfb stay white.
Also, sometimes cancelling the render also do such windows activate everything/white vfb and takes minutes to come back responsive.
This doesn't seems to happens with max vfb.
Working on heavy scene, millions polys/thousands objects
Windows 7 Pro x64 SP1+performance update
nVidia 1070
3dsmax 2018.2
V-Ray 3.60.02 (3.60.03 in deployment, let's see tomorrow)
RailClone Pro, Forest Pro, PhoenixFD up to date
If someone has idea where to look at to identify from where it could come ...![confused](https://forums.chaos.com/core/images/smilies/confused.gif)
nVidia 1070
3dsmax 2018.2
