IPR Crashes
  • IPR Crashes
    I have been crashing a lot and when I fill out the AD report, it usually has the name IPR in it. Hiding things - crash, turning things on - crash, drop HDRi in environment slot - crash. This only happens when I am in progressive mode. Anybody else?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    I have had nothing but issues with IPR for months - Multi Texture tweaks crash / forest tweaks crash. Sort of gave up using it with large scene of fear of crashing.
      Might be a FP thing, it seems to me the common denominator on my projects.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        I would be very grateful if you can give us more details on how to reproduce the issues.
        Best regrds,
          I just started a new project. I selected my siding and hit Hide Unselected and crash! Simple stuff with no extras.
          https://files.acrobat.com/a/preview/...1-4a000504b852
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            vlado regarding the crashes its always when IPR is running.
            Using floor generator if you amend a material or delete a map i get crashes,so i always have to stop IPR and then do the changes.
            Using Forest Pro i can't fully remember when it crashes, although it is mainly when editing a setting like changing the distribution map or tweaking a setting. Again if i stop IPR from running its fine.
            I just ended up having to keep remembering to stop IPR
              Thanks for the pointers; will check these cases.
                I just started a new project. I selected my siding and hit Hide Unselected and crash! Simple stuff with now extras.
                There is something messy happening with the Rail Clone objects. I will reach out to the guys at Itoo.
                Peter Matanov
                Chaos
                  Can you send me a scene for this? The only thing I found in my tests was a MultiTexture crash that doesn't have anything to do with IPR.
                  Peter Matanov
                  Chaos
                    Its not just one scene. I have just been using IPR with forest and i had a firest object turned off in layers, with IPR running i turned the layer on with another forest object and it crashed. It just doesnt happen all the time.
                      I'm having a lot of IPR crashing as well. Not just when using FP. Usually logging it with IPR and Vray in the AD reports.
                        I had a crash just now, while running IPR in RT, changing a VRayMTL into a Multi-sub-object.
                        Jez
                        3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
                        Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
                        Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
                        ---- Updated 06/09/23 -------
                          Using forest and running IPR - changing the density of distribution crashes IPR
                            Please send dump files from those crashes including info about Max and V-Ray versions at my email. You can find them in your user temp directory (%temp) - 3dsmax_minidump.dmp or/and VRay.dmp.
                            Peter Matanov
                            Chaos
                            • #15
                              Also have consistent crashes with IPR. Currently crashing with a brand new file, low geometry count. Will crash any time I try to adjust VrayDisplacement settings.
                              dav
