I have been crashing a lot and when I fill out the AD report, it usually has the name IPR in it. Hiding things - crash, turning things on - crash, drop HDRi in environment slot - crash. This only happens when I am in progressive mode. Anybody else?
IPR Crashes
IPR Crashes
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- ​Windows 11 Pro
Tags: None
Might be a FP thing, it seems to me the common denominator on my projects.Bobby Parker
phone: 2188206812
- ​Windows 11 Pro
Originally posted by leehumphries View PostI have had nothing but issues with IPR for months - Multi Texture tweaks crash / forest tweaks crash. Sort of gave up using it with large scene of fear of crashing.
Best regrds,
I just started a new project. I selected my siding and hit Hide Unselected and crash! Simple stuff with no extras.
https://files.acrobat.com/a/preview/...1-4a000504b852Last edited by glorybound; 07-08-2019, 07:45 AM.Bobby Parker
phone: 2188206812
- ​Windows 11 Pro
vlado regarding the crashes its always when IPR is running.
Using floor generator if you amend a material or delete a map i get crashes,so i always have to stop IPR and then do the changes.
Using Forest Pro i can't fully remember when it crashes, although it is mainly when editing a setting like changing the distribution map or tweaking a setting. Again if i stop IPR from running its fine.
I just ended up having to keep remembering to stop IPR
Originally posted by glorybound View PostI just started a new project. I selected my siding and hit Hide Unselected and crash! Simple stuff with now extras.
https://files.acrobat.com/a/preview/...1-4a000504b852If it was that easy, it would have already been done
Peter Matanov
Chaos
Originally posted by leehumphries View Postvlado regarding the crashes its always when IPR is running.
I just ended up having to keep remembering to stop IPRIf it was that easy, it would have already been done
Peter Matanov
Chaos
I'm having a lot of IPR crashing as well. Not just when using FP. Usually logging it with IPR and Vray in the AD reports.Last edited by markus_s_cg; 15-01-2018, 12:50 AM.
I had a crash just now, while running IPR in RT, changing a VRayMTL into a Multi-sub-object.Jez
3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
---- Updated 06/09/23 -------
Please send dump files from those crashes including info about Max and V-Ray versions at my email. You can find them in your user temp directory (%temp) - 3dsmax_minidump.dmp or/and VRay.dmp.If it was that easy, it would have already been done
Peter Matanov
Chaos
