Fillet
  • Fillet
    Why such a wonky way to fillet? Is it a MAX thing or am I doing something wrong?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    I'll get that sometimes on a weird point that has a weird bezier tangent(?). I'll select the vertice and 'reset tangets', then choose 'corner', and fillet again.
    Brendan Coyle | www.brendancoyle.com
      You need to convert the point to a corner bezier and then make sure the length of each bezier handle is the same length. That is a work around but not great to have to do with a large structure.
      Regards
      Steve
      My Portfolio
        Alternativly you can refine the spline by adding a vertex at equal distances from the corner point...making sure of course that the radius is possible within those vertices.
        Regards
        Steve
        My Portfolio
          Are all the points on the entire spline on the same Z location?
          Kind Regards,
          Morne
            Yes, they are all flat.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              disregard that one... sry.
              Last edited by piotrus3333; 26-01-2018, 04:33 AM. Reason: disregard that one... sry.
              Marcin Piotrowski
              youtube
                Check the vertices that connect to those that are acting weird, if those are bezier corners with different handle length the fillets will have different curvature. I usually select all the spline vertices and convert to corner before filleting to avoid this.
                  the vertex above have a different bezier handle length.
                    I'll check into that, good observations.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
