Does anybody else use this little script called RenderMask? It seems that it doesn't work with Vray Next. It just renders black image. It worked perfectly fine with all previous versions of Vray.
RenderMask script no longer working with Vray Next?
Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
3ds Max 2023.2.2 + Vray 6 Update 2.1
AMD Ryzen 9 9950X 16-core
64GB DDR5
GeForce RTX 3090 24GB + GPU Driver 551.86Tags: None
- Likes 1
Thanks!
...Aleksandar Mitov
64GB DDR5
This is a crucial script for us.Kind Regards,
Richard Birket
http://www.blinkimage.com
The script seems to create Standard materials in order to do its job. It will need to be reworked to create VRayMtl materials instead. It would be best to contact the author about it. I could try to do something about it on the V-Ray side, but I'm not sure how successful this will be - we can't support the Standard material forever (Standard materials severely cripple the performance of V-Ray).
VladoLast edited by vlado; 04-06-2018, 04:56 AM.I only act like I know everything, Rogers.
I just contacted the developer. He said that he has stopped development for the moment due to other priorities. Hopefully he finds the time to check it out because it's a great little script. I use it almost on a daily basis for quick masks and it's a pity he doesn't work on it anymore. Maybe if enough people donated. I did some years ago as it has saved me lots of time and money but sadly I can't find the donate page anymore.Last edited by Alex_M; 04-06-2018, 07:35 AM.Aleksandar Mitov
64GB DDR5
Use Scanline when rendering the masks? Or just use multimatte render element but this requires planning before rendering.Aleksandar Mitov
64GB DDR5
Apologies for digging up this old one, but does anyone have a working solution for this? I believe the script was fixed with version 5.90, however that version is not available to download. Does anyone have any alternative methods for very quick masks like this script did so well?
- Likes 1
It is available now http://tepavicharov.com/?p=251000 Skopje, Macedonia
contact@narsov.com
Mob. +389 71 382699
www.narsov.com
Well he updated it and vray 5 appears to have broken it. He's said that he won't be able to fix it...for now.
Ugghhhh any other alternatives? This is such an important part of my workflow
