vray materials by default
  • #61
    Oh, I figured it before. All I have to do is make the medit file have the 24 slots with this option turned on.
    I'm just running into one problem. (it's since Max 2009 & Vista "upgrade") I've adjusted the .ini file and the light/shadows are working correctly but the material editor slots aren't set up to my material library. I've double checked this several times and it should be working.
    • #62
      The first time you select a Defaults preset, 3ds Max copies it into the local user profiles folder. Further changes to the original preset folder are ignored. To get 3ds Max to load the changed preset, you need to delete the relevant preset folder in the local user profile (somewhere in the "Users" folder on Vista).
      • #63
        Vlado your awesome, thanks.
