VrayMeshLight support for ThinkingParticles and datChannel texture
  • VrayMeshLight support for ThinkingParticles and datChannel texture
    hi there the mesh light is something really great to have but it would be really better if support thinking particles (or other particles sysytems)
    try only to image if you have to do sparks that illuminate a scene with geometries and fluid grids...it would be simply amazing to just generate a lightmesh then asign the TP, this would avoid so many turnarounds and make this kind of tasks a child play...when as it is now is a huge pain
    one more important support to add is the new thinkingParticels dataChannel texture, this texture let's receive informations from inside TP and assign them to a texture so basically it makes easy to manage a shader procedurally form inside TP
    so reassuming the good procedure would be to assigh TP as mesh into the VrayLightMesh then assign the dataChannel texture in the VrayLightMesh as well then assign this light to the fluid grid, (vray - fumefx - openVDB ans so on) and the result is to get perfect illumination based on procedural data coming from inside thinkingparticles
    this feature is something that we miss a lot
    Why not use the lightmaterial with direct lighting on?
    The performance is analogous to that of mesh lights.
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      FumeFX does not support that option, it only supports lights so to have illumination from particles the only way is to use the MeshLight from Vray
        It's likely much easier for FFX to support our light material than for us to support TP as sources in a light.
        I'll raise this to the devs, regardless.
        Lele
        Disclaimer:
          hi Emanuele actually i turnaorund this with the alembic exporter but the dataChannel texture support is missing anyway
          if a direct support is not possible due to other priorities it could be anyway useful to have this TP texture supported so i can control the color of the lights per particle
          let's see what's coming out from the FumeFX 6 that looks very promising...maybee they have already considered this missing feature
          thanks for your time
