curvature shader
  • #16
    The mia_material of mental ray has nice features, in max it's called Pro Materials i think. this is one of its feature. Round corners. you can choose in the material the option to round corners or not. you can even specify a fillet radius with images or with math operators. and you can even blend the fillets between more than one material.
    it would be a very very nice option for vray i think. would save a lot of time in modeling.
    those things add a lot to images.
    • #17
      that would be an extended vray edge map i think?
      you can currently use it in the bump channel for the round corners effect, but not for masking i think.
      Sascha Henrichs
      Piranha-Bytes
      Graphics
      www.saschahenrichs.com
      • #18
        i don't think this has anything to do with vray edge tex map...
        • #19
          Originally posted by aphexx View Post
          really? i will give it a try, but i doubt one can achieve those corners on any covexity of a mesh.
          did you ever used the map for this effect?
          Here's a quick test. VRayDirt using inverted normals, same object only, not ignoring for GI and a fractal noise map in the radius slot. I used the vray dirt map as the mask in a mix map so I could control edges better (the rust edges stop fairly quick instead of fading that you'd normally get with vraydirt). The mesh on the left is just a meshsmoothed version of the one on the right. It's not perfect and really isn't the same as a curvature shader but it gets the job done in a lot of cases.
          • #20
            the whole point of a geometry shader which could round corners is actually to avoid meshsmooth, and keep the geometry as light as possible, while detail is added at rendertime.
            • #21
              Here's a quick test. VRayDirt using inverted normals, same object only, not ignoring for GI and a fractal noise map in ....
              dlparisi, this is just cool. i'm stunned. i didnt know, that you can use the edge map also as a mask but only as round corners and wire effect.
              very cool!
              @mikemax: my first preference of a geometry shader is having automated shading and in consequence less work.
              are you aware, that when you place the edge map in your bump channel, it actually does a "round corners" effect? its not having much options but world units to set the amount of the "roundness" but it does the trick somehow
              Sascha Henrichs
              Piranha-Bytes
              Graphics
              • #22
                very cool!
                he just said he made the round corners with meshsmooth, not with edgetex..
                • #23
                  Didn't he want to get rusted edges where the geometry was already curved? That's what I got from his first post.
                  You can always use the VrayEdges texture to round the corners anyways.
                  • #24
                    ah yes ? and how ?
                    the vray edge tex is to simulate the wireframe effect i thought ? how could it round the corners ?
                    • #25
                      ah yes ? and how ?
                      you put it in the bump slot. Vray has had this capability for a bit now.
                      • #26
                        thanks for the tip, i didn't know.... does it work well (quality, control...) ?
                        • #27
                          yes. that is what he wanted very cool solution. thank you for this tip!
                          Sascha Henrichs
                          Piranha-Bytes
                          Graphics
                          • #28
                            yes sorry, i took his wishes for mine.... i should open my own wish thread
                            • #29
                              How did you get the orange edges so orange...when I try this, my edges where the vray dirt shows are very faint..the vraydirt shader seems to falloff very quickly and not be true black and white to use as a mask...
                              Regards
                              Steve
                              My Portfolio
                              • #30
                                I used the vraydirt map in the mask slot of a mix map. If you check the Use Curve button in the Mixing Curve section you can then make a steep dropoff wherever you'd like the color to stop. So with this you can have a 60% grey value be 100% orange (or whatever number suits your need) and then very quickly drop off to be 100% green once the dirt value is say 55%. Hope that makes sense.
