Stereoscopic vray physical camera
  • Stereoscopic vray physical camera
    Yes, I know, there are several scripts or plugs to implement stereoscopic cameras inside Max.
    I use XidMary and I constrain vray cameras to this rig, I can animate the toening but this plug doesn't work well because uses Max legacy camera.
    Would be nice to have a stereo native vray physical camera rig
    Best regards.
    We have a small helper that causes V-Ray to render two side-by-side views; it works with any kind of camera. Not sure if it would go into the next build or not, but we'll see.
      Hi Vlado,
      Are there still plans to include this?
      thanks,
      Eric.
        The source code for this is actually included with the V-Ray SDK for SP4, although it is not compiled to a binary form. I can try to do that along with the bump2normal plugin.
          Thanks!
          e.
            any updates on this?
            Kind Regards,
            Morne
              Yes, you can find it here:
              http://www.spot3d.com/vray/misc/vraystereoscopic.rar
                I get an error with the 2009 x64 version
                Nils Poetoehena
                3D Visualiser
                www.demanufacture.org
                www.gielissen.com
                  What kind of error?
                  [EDIT] Works for me when I tried it just now...
                    Here's a screenshot
                    Nils Poetoehena
                    3D Visualiser
                    www.gielissen.com
                      Which version of V-Ray do you have? It works for SP3/SP3a/SP4/SP4a only.
                        I have sp4a on 3dsmax2009 64bit
                        Nils Poetoehena
                        3D Visualiser
                        www.gielissen.com
                          Ok; which folder did you copy the file to?
                            if you look at the error message he copied it into the root plugins folder. Does it need to go into the vrayplugins folder maybe?
                              just confirmed it worked fine after making sure it was put into the vrayplugins folder.
