circular plane light
  • circular plane light
    any chance to get circular vray plane light ?
    Luke Szeflinski
    :: www.lukx.com cgi
    why not just use a circle with vraylight material set to direct illum, or a vraylight in mesh mode linked to a circle?
      Why not just code it into VRAY....It can't be that hard???????
      Why use work arounds when you should have the right tools for the job.??
      This is one light I would use EVERY project...if it was availble.
      +10 votes for this from me
        exactly
        Luke Szeflinski
        :: www.lukx.com cgi
          ok fair point
          +1 from me :P
            It's been requested many times before, so I would guess it is not a trivial task or Chaos would already have it in place. I would like it too though
            Brett Simms
            www.heavyartillery.com
            e: brett@heavyartillery.com
              I would use this every project.
              Nat Saiger
              Portfolio
                I would use it a lot as well.
                More than the square light for sure.
                  I too would use this on EVERY project.
                    +1 random characters here to make the character count...
                    Colin Senner
                      What is ask here isn't simply a Vray Light with a radial gradient map in his texture ?
                        How about a spherical VrayLight with a height of 0?
                          it's not work because reflections will be always a sphere.
                          Render and Animation - WWW.IMERGO.IT
                            +1 to this, could use this right now for some ceiling lights. Would make setting up simple ceiling lights a whole like easier. I could also leave my lights visible to reflections since they'd match somewhat the shape of the fixture.
                            Brendan Coyle | www.brendancoyle.com
                              +1. Just had an instance where I was wishing there was a default 'disc' shaped light.
                              Akin Bilgic | CGGallery.com
                              Modeler & Generalist TD
                              V-Ray Render Optimization
                              V-Ray DMC Calculator
