Thank you Vlado, the fix looks like a pretty huge improvement. Going to check it out right now in the nightly.
A Quantized-Diffusion Model for Rendering SKIN and Translucent Materials
I just checked it out and it does seem to be a very nice improvement. However I noticed one very odd thing - turning legacy mode off seems to turn the fix off - the opposite of what I would expect. I checked it a bunch of times to make sure I'm not going crazy. Using the latest nightly with Max 2012.
Originally posted by vlado View PostSo the pesky greenish tint bug is fixed now; one of the formulas for calculating the volume properties out of the sss color was wrong - it is also wrong in the original bssrdf paper that I followed
Thanks for sticking with me on this one. I am so glad you tracked down what the bug was. And yeah it always seems that there are typos in the published papers. WOW, I cant tell you how stoked I am.
Will the patch make its way back to 1.5? We are still using it here at the office.
Thanks again!
-Michael
p.s. Heres a case of the same thing http://photorealizer.blogspot.com/20...flectance.html
Originally posted by adamlewis View PostI just checked it out and it does seem to be a very nice improvement. However I noticed one very odd thing - turning legacy mode off seems to turn the fix off - the opposite of what I would expect. I checked it a bunch of times to make sure I'm not going crazy. Using the latest nightly with Max 2012.Other than that, you will need a two-layered shader to avoid this effect (f.e. vrayblendmtl with two sss2 materials in it). With a single shader, it is not possible to avoid it - as more red light reaches down into the object, there is less red towards the surface, so small details appear cyan-ish. (If you think about it, a very small flake of skin is not really pink, but whitish).
Here is a render with a VRayBlendMtl with two sss2 materials in it: the base material is dark red with larger scatter radius; the first coat material is another sss2 material with pink sss and scatter color.
In any case, with the legacy method, the extinction of the light inside the volume followed slightly different curves for red/green/blue components, and this lead to an apparent shift in color hue - so the orange juice above ended up being greenish. My change only forces the three color curves to attenuate in the same way, which preserves the color hue of the light as it propagates through the volume.
Originally posted by vlado View Post(snip)...it is not possible to avoid it - as more red light reaches down into the object, there is less red towards the surface, so small details appear cyan-ish. (If you think about it, a very small flake of skin is not really pink, but whitish).
There is no reason for less red light to bounce back or through, if more of it penetrates the medium. Quite the opposite I'd say. You can test this if you want in a murky puddle of water, or your own flesh with a coloured light source.
If the medium it self has the ability to absorb the red wavelength, then you would not get cyan scattering as intense as we seem to get. We expect something similar, just a tad less red.
However, when it comes to skin\flesh, it doesn't absorb red as in these examples, it actually absorbs the other wavelengths more, thus producing a beige-to-red tinted scatter (depending on the depth), and the deeper it has been scattered, the redder it gets.
What we expect then, is for the controls on the materials to reflect our expectations, as humans, not robots, thus we expect the colour we set in a swatch to be the colour we get as a result, more or less.
The inner workings of the shader can still be mathematically correct, but that is for programmers and computers, not your run of the mill illustrator.
We just need a better interface, where the colour is defined as the result\goal, and the shader does the required maths to work out the "wavelengths" and such.Signing out,
Christian
Originally posted by vlado View PostThe odd thing is that the "legacy" mode is still how the shader used to behave beforeOther than that, you will need a two-layered shader to avoid this effect (f.e. vrayblendmtl with two sss2 materials in it). With a single shader, it is not possible to avoid it - as more red light reaches down into the object, there is less red towards the surface, so small details appear cyan-ish. (If you think about it, a very small flake of skin is not really pink, but whitish).
[ATTACH=CONFIG]12609[/ATTACH]
I had no idea it was possible to layer sss2 materials in the way you describe, mostly because I just assumed the vrayblendmtl could only blend surface changes as opposed to changes within a volume. If that's the case then that it would certainly add a lot of control and presumably allow us to achieve very realistic skin and other heterogeneous materials. Are there any limitations to this approach?
With that thought in mind, I was curious what a homogenous scattering material would look like in real life, and I found a very interesting example in the form of a silicone mask - as you can see in the picture I attached it exhibits the exact same green tinting you see in the sss2 shader, so the shader does seem to be behaving in a physically accurate way.
Your homogeneous example does not exhibit this behaviour. You can open it in Photoshop and sample the colours. They look "cold" to the eye, but that is because of the contrasting redness elsewhere. All the colours I sampled had more red in them than green or blue. The areas where the material is producing highlights (not just the inner sharpest parts, but also the areas around it), are also affected by the fact that the light source is "cold", slightly blue-ish (as seen on the background). Try Adjusting the white balance first by getting the paper more neutral.
Just wanted to point out that this does not support the logic.Last edited by trixian; 14-01-2013, 01:14 PM.Signing out,
Christian
Originally posted by trixian View PostYou can test this if you want in a murky puddle of water, or your own flesh with a coloured light source.However, to see the effects that we discuss here, you'd need to look at distances a few parts of the millimeter away from the light source. With the scattering coefficients that there sphere above was rendered with, it would have to be about 2 mm wide, and just one of the displaced bumps would probably be like 0.2 mm. It would be very hard to observe changes in material appearance with a naked eye at this scale
The two-layer approach is much more artist-friendly and probably the best we can hope for now. Plus, skin is not really homogenous, so trying to mimic it using a single sss material is not a very good approximation to begin with.
VladoLast edited by vlado; 14-01-2013, 01:44 PM.I only act like I know everything, Rogers.
Originally posted by trixian View PostYour homogeneous example does not exhibit this behaviour. You can open it in photoshop and sample the colours. They look "cold" to the eye, but that is because of the contrasting redness elsewhere. All the colours I sampled had more red in them. The areas where the material is producing highlights (not just the inner sharpest parts, but also the areas around it), are also affected by the fact that the light source is "cold", slightly blue-ish (as seen on the background).
VladoLast edited by vlado; 14-01-2013, 01:33 PM.I only act like I know everything, Rogers.
Originally posted by trixian View PostYour homogeneous example does not exhibit this behaviour. You can open it in Photoshop and sample the colours. They look "cold" to the eye, but that is because of the contrasting redness elsewhere. All the colours I sampled had more red in them than green or blue. The areas where the material is producing highlights (not just the inner sharpest parts, but also the areas around it), are also affected by the fact that the light source is "cold", slightly blue-ish (as seen on the background). Try Adjusting the white balance first by getting the paper more neutral.
Originally posted by adamlewis View PostI had no idea it was possible to layer sss2 materials in the way you describe, mostly because I just assumed the vrayblendmtl could only blend surface changes as opposed to changes within a volume. If that's the case then that it would certainly add a lot of control and presumably allow us to achieve very realistic skin and other heterogeneous materials. Are there any limitations to this approach?
The setup is a bit cumbersome though; what I'm thinking is that we can probably build this into the sss2 shader itself, so that you get two sss layers to play with.
As for the putty clay image, how is it a shift towards green as opposed that actually being the "surface colour", and the rest is actually shifted towards red instead?
I still think the glossy highlights from the light are skewing your perception of it as well as the images white balance.Signing out,
Christian
