Re: V-Ray/Blender 2.49.12 Build
Yep, I also mention this... try to find out the way to fix.
If its really needed I could add this in 2.4, but this will be in 2.5 definitely.
it doesn't also export a combined render, just all the separate passes, it'd be great if you could get all the passes AND the full render
when exporting the passes, you get ALL the passes, which takes up a lot of time and clutter. Would it be possible to select the passes you want to export? That would greatly improve the compositing workflow.
