Depth Of Field + Motion Blur Bug
  • Depth Of Field + Motion Blur Bug
    Seems like, the only time it's being respected in the animation sequence is frame #1, all consecutive frames 20210908 Windows Standalone RTX GPU Render are being ignored. I think that issue is not unique to the GPU and is replicable in CPU render as well.
    Frame #1:
    Frame #2:
    Focus is baked into the camera.
    Project to reproduce this issue:
    https://drive.google.com/file/d/1664...ew?usp=sharing
    Progressive CPU Mac Render. DOF + MB appears to be respected in this test.
    Frame 1
    Frame 2:
      Progressive CPU Windows Stand Alone. Appears to not respect DOF + MB past frame 1. So it's not a GPU issue, it is the ability of the remote node to read project information properly issue.
      Frame 1:
      Frame 2:
        [QUOTE=imdb;n1124612]Progressive CPU Windows Stand Alone. Appears to not respect DOF + MB past frame 1. So it's not a GPU issue, it is the ability of the remote node to read project information properly issue.
        Oh… I will test it tomorrow.. As I would need mb soon for my next project.. I hope this bug is not back… this was definetly fixed in a hotfix… took longer for cg to fix it for command line rendering, like rebusfarm is using it…
        I assume you are using a young build?
        BTW, I mean mb only, never used it with dof together…
          Build: 20210908
          My bad, MB is fine, only DOF is busted.
          Found a temporary fix. Enabling DOF in Overrides Tab forces Frame 2 > to respect the DOF.
            Hello imdb,
            This is a known issue that has been reported previously here. It has already been reported (bug ID: VC4D-915) and I will let you know once we have more information on the matter. Thank you.
            Aleksandar Kasabov
            chaos.com
