fog + water surface
  • fog + water surface
    Hi everyone,
    I have a simple underwater scene as you see in the first picture.
    The camera is placed beneath a plane with a water material. The plane you are looking at has a deformer to get the (simple) waves. The normals are pointing upwards.
    So this looks as expected.
    But if you turn on the environment fog - to get more depth to the scene - the surface disappears and you look into the sky.
    Is this an issue? Can you give me a tipp how to render the water and fog together? For now I turn the plane around so the normals are pointing down but this doesnt look good.
    Scene is attached.
    Best - klex
Name:	subsea fog 01 0001.jpg
ID:	1137173Click image for larger version
Name:	subsea fog 01 0002.jpg
    Reverse the water surface normals, then it should work.
    You can also try using the aerial perspective.
    3D Scenes, Shaders and Courses for V-ray and Corona
    NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
    @3drenderandbeyond on social media @3DRnB Twitter
      Hi Sirio,
      as I already wrote this is my workaround right now but this looks not as expected:
Name:	subsea fog 01 0003.jpg
      Oh I didn't know that aerial perspective is implemented already (I was waiting for a long time). I will give a try.
      Thanks
        The aerial perspective is in the latest build. Try this in the mean while, using your original setup you can put your camera inside a sphere with reverse normals:
Name:	Schermata 2022-01-20 alle 11.28.47.png
          Nice idea with the sphere around the camera. Its is working in my simple test scene with a perfect refraction. But if the refraction glossiness is lower then 1 the image is getting blurry. Also with an additional bump map this is tricky.
          So If I have a komplex material for the water and a simple glass material for the sphere the water is gone again. It seems that this must be the same material for the water and the sphere to see the water. I hope this is not too confusing!
          You proposed the use of aerial perspective but I got the same issues as with the fog.
            Hi chaos-team, no response on this issue?
              Hello klex167,
              Apologies for the delayed reply.
              This seems to be a bug that only happens when rendering with V-Ray but is not reproducible if rendering with V-Ray GPU. I have reported this to our developers (bug ID: VC4D-1259) and I will let you know once we have any updates.
              Aleksandar Kasabov
              chaos.com
                Hey, klex167,
                Could please enable the "Refract Thin Walled" option available in the Refraction menu as well and check if it works for you.
                Cheers,
                Boyan Nalchadjiiski | QA Engineer @ Chaos |
                E-mail: boyan.nalchadjiiski@chaos.com
                  Hi Boyan,
                  unfortunately the water is (almost) gone again with the "refract thin walled" option. Even without the fog.
Name:	subsea fog 04.jpg
                    Hey guys, are there any updates on this issue?
                    I have to cope with this almost every day and my customers are pretty unhappy.
                    Best - klex
                      Hello klex167,
                      I am afraid that we don't have any updates yet. I have additionally boosted the priority of the issue and I will let you know as soon as we have any updates. Thank you.
                      Aleksandar Kasabov
                      chaos.com
