Vertex Map not growing in render
  • Vertex Map not growing in render
    Hey again,
    I want to work on a shader effect, that requires a vertex map to grow naturally. I have a simple setup attached.
    The goal would be to generate a burn effect, simular to this picture (from a tutorial, not identical result in mind, but the conecpt is the same):
    In a quick test I got this effect running in the interactive renderer:
    But when I want to render the whole animation, I get this result:
    This represents the sphere field, with which I start the growth animation of the vertex map. Is VRAY 6 not capable of recognizing growing vertex maps or do I have a weird bug in my scene? Thanks in advance for the help
    Hello jonas_schneider,
    Can you please let me know what are the exact versions of Cinema4D and V-Ray that you are using? Thanks.
    Aleksandar Kasabov
    chaos.com
      I am using C4D 2023.1.3 und VRAY 6.00.04
        Can you try updating your Cinema4D to the latest version (2023.2.1) as from our tests it seems like this issue is not reproducible with this version of Cinema4D. Thank you.
        Aleksandar Kasabov
        chaos.com
          Made a clean install of C4D and VRAY, works now as intended. Thanks for the support
            I am glad to hear that updating the software resolved the issue. Should you have any further queries, please don't hesitate to let us know
            Aleksandar Kasabov
            chaos.com
