Hello,
This question is half V-Ray half deadline, but I thought I'd try here first. I have V-Ray 6-20-02 and Cinema 4D R2024-4-0 working in Deadline 10-3-2-1, however I am not getting any logging on the deadline side (like what's in the VFB 'Log' pane). There's some basic info from Cinema, but not from V-Ray, but it doesn't seem to be connected to the verbosity settings in C4D Prefs - Renderer - V-Ray - Logging. I noticed to deadline there's V-Ray 5+ and not 6, but I don't think much has changed there so that's probably not the issue. I've verified the frames are rendered by V-Ray as expected via the exr metadata.
Here's an example of some of the info from the deadline render log, to task completion:
There's no mention of V-Ray in the log outside of envars and loading the plugin, if I use the V-Ray Output System in Common, the logs sometimes have a few lines about that:
Thanks,
Jens
Code:
STDOUT: JSON file already generated STDOUT: Rendering frame 10 at date STDOUT: Rendering Phase: Setup STDOUT: Progress: 0% STDOUT: Progress: 100% ... STDOUT: Progress: 100% STDOUT: Progress: 0% STDOUT: Progress: 4% STDOUT: Progress: 19% STDOUT: Progress: 24% STDOUT: Progress: 35% STDOUT: Progress: 45% STDOUT: Progress: 51% STDOUT: Progress: 57% STDOUT: Progress: 62% STDOUT: Progress: 64% STDOUT: Progress: 70% STDOUT: Progress: 79% STDOUT: Progress: 88% STDOUT: Progress: 95% STDOUT: Progress: 100% STDOUT: Progress: 0% STDOUT: Progress: 18% STDOUT: Progress: 100% STDOUT: Progress: 0% STDOUT: Progress: 100% INFO: Task Overall Progress: 100.0% STDOUT: Rendering Phase: Finalize STDOUT: Rendering successful: 8 sec. STDOUT: Warning: Unknown arguments: true INFO: Process exit code: 0 INFO: Finished Cinema 4D Task Done executing plugin command of type 'Render Task' z
Code:
INFO: Render Tasks called INFO: Pre Build Script INFO: Validating the path: 'output' INFO: Rendering main output to network drive INFO: Validating the path: 'output' INFO: Rendering VRay 5 output to network drive
Jens
