V-Ray for Cinema 4D and Deadline Logging
  • V-Ray for Cinema 4D and Deadline Logging
    This question is half V-Ray half deadline, but I thought I'd try here first. I have V-Ray 6-20-02 and Cinema 4D R2024-4-0 working in Deadline 10-3-2-1, however I am not getting any logging on the deadline side (like what's in the VFB 'Log' pane). There's some basic info from Cinema, but not from V-Ray, but it doesn't seem to be connected to the verbosity settings in C4D Prefs - Renderer - V-Ray - Logging. I noticed to deadline there's V-Ray 5+ and not 6, but I don't think much has changed there so that's probably not the issue. I've verified the frames are rendered by V-Ray as expected via the exr metadata.
    Here's an example of some of the info from the deadline render log, to task completion:​
    Code:
    STDOUT: JSON file already generated
    STDOUT: Rendering frame 10 at date
    STDOUT: Rendering Phase: Setup
    STDOUT: Progress: 0%
    STDOUT: Progress: 100%
    STDOUT: Progress: 4%
    STDOUT: Progress: 19%
    STDOUT: Progress: 24%
    STDOUT: Progress: 35%
    STDOUT: Progress: 45%
    STDOUT: Progress: 51%
    STDOUT: Progress: 57%
    STDOUT: Progress: 62%
    STDOUT: Progress: 64%
    STDOUT: Progress: 70%
    STDOUT: Progress: 79%
    STDOUT: Progress: 88%
    STDOUT: Progress: 95%
    STDOUT: Progress: 18%
    INFO: Task Overall Progress: 100.0%
    STDOUT: Rendering Phase: Finalize
    STDOUT: Rendering successful: 8 sec.
    STDOUT: Warning: Unknown arguments: true
    INFO: Process exit code: 0
    INFO: Finished Cinema 4D Task
    Done executing plugin command of type 'Render Task' z​
    There's no mention of V-Ray in the log outside of envars and loading the plugin, if I use the V-Ray Output System in Common, the logs sometimes have a few lines about that:
    Code:
    INFO: Render Tasks called
    INFO: Pre Build Script
    INFO: Validating the path: 'output'
    INFO: Rendering main output to network drive
    INFO: Rendering VRay 5 output to network drive​
    Thanks,
    Jens
    Pardon all the edits, forum issues with editing or posting pasted content, re: this post due to a vBulletin 403 error
    Dear Chaosgroup, can you please improve this forum. It is riddled with bugs and weird behaviour. One example, if I paste some text from a text editor I get the following error: ​ First there shouldn't be any errors pasting some normal text and if there were, this error message doesn't help anyone. It really is UX101. Also
