[PHI-5937] Subsampled VDB Velocity
  • [PHI-5937] Subsampled VDB Velocity
    Does subsampled vel work with VDBs yet?
    Hey Dubbie99 ,
    Apologies for the late reply - I just now saw the thread while browsing the forum.
    The R&D team have been busy working on anisotropic scattering and support for render elements in Volumetric mode - we still haven't had the chance to add subsampled vel support.
    In case it's the look that is produced with a subsampled velocity channel that you are after, you could use the VDB Smooth SOP to give the velocity channel a couple of smoothing iterations.
    Hope that helps!
    gosho.genchev@chaosgroup.com
      It's more about that downsampled velocity significantly reduces the cache size.
      Hristo Velev
      MD/FX Lead, Bottleship VFX
      Sofia, Bulgaria
        Hristo is right.
        You can cut your cache sizes to less than 1/3 the size by subsampling the velocity with virtually no effect on the render.
        Uncessesarily large caches are very expensive in disk space and time.
        I think this should be treated as a high priority item. It will help more people than the other features (Although they will be very welcome too!)
          I asked for this a while back. So hopefully it gets done now.
          https://forums.chaos.com/forum/v-ray...ds-not-working
