(Closed, Open, Closed) [HOU-1635] [HOU-1644] [HOU-1645] Shadow catching workflow
    Awesome!
    Would you mind also clarifying point (4) from the post above - I'm wondering if there's something we can do to simplify things.
    is it possible to get these light contribution affecting the plate into separate render elements?
    This got me really confused because what I'm reading is likely different from what you meant. I understand this as "Is it possible to get a light select for the matte geometry ?"
    All the best!
    gosho.genchev@chaosgroup.com
      Originally posted by Gosho.Genchev View Post
      Awesome!
      I created a scene with some of the render layers we need to setup that would be awesome if they actually ended up in the render elements of a single render layer instead.
      shadowCatcher_v003.zip
      Head of Lighting @ Goodbye Kansas Studios
        Image of render ops and takes
          Here are some images of the render ops:
          Click image for larger version  Name:	vray_4_CG_objects.png Views:	1 Size:	250.4 KB ID:	1061635
          Fig. 4.2 Beauty of CG_objects with black background and no shadows or reflections in alpha.
          Click image for larger version  Name:	vray_4_reflection.png Views:	1 Size:	137.0 KB ID:	1061636
          Reflection component with reflection alpha in the alpha channel.
          Proposed render element: reflection (4 channels)
          Click image for larger version  Name:	vray_4_reflectionFilter.png Views:	1 Size:	61.0 KB ID:	1061637
          Reflection filter
          Click image for larger version  Name:	vray_4_shadows_combined.png Views:	1 Size:	217.8 KB ID:	1061638
          Shadows rendered on a white background. Colored shadows that can be multiplied on the bakcplate in comp.
          Proposed render element: shadow, rawShadow, matteShadow, lighting, rawLighting
            Hannes Drossel
            1. Images are not attached.
            2. Does the stuff you want works in Maya?
            andrei.izrantcev@chaos.com
            Support Request
            • #21
              Could not get a separate render of GI component. Would take this GI render minus above combined shadow render in Nuke to get GI separate from shadows and on a black background.
              Proposed render element: GI
              Realized there are some mistakes made in the previous files I sent. The takes were not working correctly.
              There are some things happening with takes. I will compile a scene and sen to you.
              This is the updated files:
              shadowCatcher_v004.zip
              • #22
                These renders are the shadow mattes that ideally would be outputted per light select.
ID:	1061632Click image for larger version
ID:	1061633Click image for larger version
                • #23
                  Originally posted by bdancer View Post
                  Hannes Drossel
                  1. Hope it works now.
                  2. No this stuff does not work in Maya
                  • #24
                    2. Then I'm not sure we could do anything about it.
                    Ok, will be great.
                    Support Request
                    • #25
                      To clarify the above posts.
                      What I would like (and I realize it may not be possible) is for all of the above images to come out of two separate renders.
                      Render 1: Fig. 4.2 Beauty of the CG objects.
                      Render 2: Reflection w alpha, reflectionFilter, shadowsCombined, GI, shadow mattes per light select in separate render elements. All in one render.
                      Thank you for taking a look at this stuff!
                      Cheers!
                      • #26
                        That is a shame
                        Here is a video from Clarrise. Showing their take on integrating CG into plates. They are showing the AOVs coming out of the single render.
                        https://youtu.be/_5PqNrrXKJY?t=215
                        Would be great, if not possible to add these features now, to include them in a future release of Vray.
                        • #27
                          Yeah, that's an understatement
                          Would this make sense / be use-able for you ? We can default those 2 lists to "*" - it is what happens currently anyway.
                          ​​​​​​My thinking is that the Reflection/Refraction Mask menus on the Render tab of the Geometry node do not list lights in the pop-up window anyway (and that's by design) - you'd have to manually type the light paths. With our own lists in the object properties, we could at least make this easier.
                          The downside is that you'd be excluding reflections of geometry in one place, and reflections of lights in another.
                          Gosho.Genchev Do you know when this feature will be implemented?
                          • #28
                            Devs have already implemented, there's a minor issue that needs fixing which the devs are already looking into - I'll ping you once you can grab a new build.
                            As to the REs workflow above - we might be able to figure something out to make your lives easier - I'll be looking into this today.
                            All the best!
                            • #29
                              Hannes Drossel , the Reflection / Refraction masks on the Object Properties are available in the nightly builds.
                              Best regards!
                              • #30
                                Best regards!
                                Thank you! This is now working.
                                Did you find any solution for the other stuff?
