(Open, Fixed, Resolved) [HOU-2211] [HOU-2210] [HOU-1845] Open subdiv on alembics
    Hey David,
    the OpenSubdiv issue with nodes inside subnetworks should be resolved now.
    We are also thinking of a way to de-couple the V-Ray Subdivision from the Displacement properties.
    Hope that helps!
    gosho.genchev@chaosgroup.com
      Awesome, thank you so much, already tested and it's working
      Hope that helps!
      I think it makes sense, users that come from other render engines will have an easier time.
      Best,
      David.
      David Anastácio // Accenture Song - VFX
      https://www.accenture.com/us-en/serv...visual-effects
        Curious why V-ray doesn't have a button like this... "Render Polygons as Subdivision" V-ray (not mantra) -- The displacement > but turn off displace and render as subD works well.
          Hello garretthoyos ,V-Ray can render polygons as subdivision, but this option is located under displacement properties menu.
          Georgy Chakarov | QA
          www.chaosgroup.com
          georgy.chakarov@chaosgroup.com
            Hey chakarov,
            As I stated on my other post: https://forums.chaosgroup.com/forum/...54#post1100854
            This displacement subdivisions are not good to use, they are much slower than openSubdiv. Anyway I could have an answer in that post?
            Best,
            David.
            • #21
              Okay I actually found the object properties on the shelf when selecting geo adds an extra tab to the geo parms and then I can set it to render as SubD much like the mantra way.
