(fixed)[HOU-2740]Vray Fur doesn't handle more than one Texture Attribute
  • (fixed)[HOU-2740]Vray Fur doesn't handle more than one Texture Attribute
    hi, for some reasons it seems that Vray Fur doesn't handle more than one Texture Attribute. I have several noise SOP that I want to use to change initial direction or density. As soon as more than one attribute is checked the fur is no more generated... anyone experience the same issue?
    Is it possible to take a look at the hip file?
    andrei.izrantcev@chaos.com
    Support Request
      Hello creac, I've reproduced and logged the issue.
      Is your mesh has uvs?
      If I add uvs on mesh the fur is rendered as expected. Is this workaround works for you?
      Georgy Chakarov | QA
      www.chaosgroup.com
      georgy.chakarov@chaosgroup.com
        Hello chakarov, that's correct. Fur needs mesh with uvs to properly work with multi texture attributes, plus all attributes need to be vector (as soon as you mix float and vector it doesn't seem to work). Thanks
          Hello creac, the issue is fixed in latest nightly build.
          www.chaosgroup.com
            Hi chakarov , I can't see any recent build in the nightly folder. Are your sure it's been upload? Thx
              Dear creac, hello.
              Yes, they are available.
              Please send me in a private message a screenshot what you are seeing, when opening the nightly build section, and I will contact the dedicated team to solve this.
              TS
              Tsvetomira Girginova | chaos.com
              3D Support (AEC,HOU,C4D) Team Lead | contact us
