hi, for some reasons it seems that Vray Fur doesn't handle more than one Texture Attribute. I have several noise SOP that I want to use to change initial direction or density. As soon as more than one attribute is checked the fur is no more generated... anyone experience the same issue?
(fixed)[HOU-2740]Vray Fur doesn't handle more than one Texture Attribute
Is it possible to take a look at the hip file?
Hello creac, I've reproduced and logged the issue.
Is your mesh has uvs?
If I add uvs on mesh the fur is rendered as expected. Is this workaround works for you?
- Likes 1
Dear creac, hello.
Yes, they are available.
Please send me in a private message a screenshot what you are seeing, when opening the nightly build section, and I will contact the dedicated team to solve this.
TS
