User String Attributes Called inside Materials
  • User String Attributes Called inside Materials
    Tested with
    Windows 10
    Nightly Builds from Jan 27th and Feb 7th
    Houdini 18.5.563 & Houdini 19.0.455
    I'm not sure if this is expected behavior or a bug. My understanding has been if a user attribute is called in a material then we didn't have to force the attribute under shading in the object properties.
    Does this apply to user string attributes too?
    Right now I have a user string attribute called texturePath on the my geo that points to a path on disk to my texture. In the shader I call the string attribute <texturePath>
    The texture will not render unless I force it.
    Just wondering if this is a bug or intended behavior.
    Thanks,
    David
    Currently, no. You'll have to force it.
    andrei.izrantcev@chaos.com
    Support Request
      Will be forced automatically in the next nightly build.
      Support Request
        Thank You!
