ocean spectra for displacement
  • ocean spectra for displacement
    Im doing some ocean renders and it made me wondering if its possible to make a vray node taking use of houdinis spectra and masking for oceans like in "ocean sample layers" vop node.
    We can ofcourse bake out a displacement but then we need a whole frame range with very high resolution textures or bake it to geometry which becomes quick super heavy.
    Checking for quriosity
    Regards Alexis
    https://www.sidefx.com/docs/houdini/...plelayers.html
    http://goodbyekansasstudios.com/
    It's could be very nice and usefull.
    GHiOM = Guillaume Gaillard
    freelance 3D artist
    www.ghiom.com
      Devs already working on to this, but it's not ready yet.
      Georgy Chakarov | QA
      www.chaosgroup.com
      georgy.chakarov@chaosgroup.com
        Excellent! Looking forward to this.
          Is there any progress on this?
            Not much, I'm afraid. We added a texture that can be used to sample volumes and return color information. We now need to add another one that can convert the phase/amplitude etc volumes from the spectrum into something suitable for displacement, and we also need to figure out a solution for the masks. Then we can package this all up into something similar to the Ocean Sample Layers VOP.
            Rendering those spectrums directly would be an incredibly useful feature so I'm also here hoping we can get it working as soon as possible.
            Best regards!
            gosho.genchev@chaosgroup.com
              Thanks for the update Gosho. I think this will be a very valuable feature. It seems like a large number of jobs involve water surfaces of some sort.
                Just thought this could be interesting to share. Like the idea of running vex directly in the render.
                https://www.marcelruegenberg.com/blo...-ocean-spectra
                  Man, vex shaders in vray would be amazing.
                    LeoYfver
                    Indeed, we were considering this. It would mean having to set up HEngine licenses on the farm and render through Houdini instead of V-Ray Standalone, however - I'm wondering if that sounds reasonable?
                    Best regards!
                      hm, true. Would cost alot with that many licenses for us. Would we be able to switch?
                      Regards Alexis
                        Yeah, I suppose if you're not using anything VEX-related, it won't be an issue to send the scenes straight to standalone.
                        However, we will probably look into this after adding Oceans support as discussed above.
                        Best regards!
                          We need oceans very often, so a robust solution is important for us. Last time we baked it - single bakes above 8K are indeed slow, so the wedge ROP helps to split up the geometry into regions and bake these in parallel on the farm. It's not as fast and high res as sampling the spectra, but it's workable.
                          There are problems with motion blur with animated displacement though, which I have reported.
                          Hristo Velev
                          MD/FX Lead, Bottleship VFX
                          Sofia, Bulgaria
                            Being able to read spectrum volumes in vray to generate the displacement would really really useful.
                            This is one of the constant fights everytime you don't render in mantra.
                            • #15
                              Yep another bump from me here too. This would be a very welcome feature.
