LPE Full Diffuse and Full Reflection +Specular?
    Originally posted by Buck View Post
    I've sent you a PM with a test file Looking at this again, it appears that the hair material is the only one not working.
    Thank you. Something odd is happening, which does not seem to appear in 3ds Max with a similar setup (I'll investigate this). It seems T* gives some kind of additional info when rendering VRayHairNextMtl which is not present in the RGB, whereas <T[GS]>* is correct.
    In other words, try these:
    2. Direct Lighting, GI and SSS through Refractions
    Code:
    C<T[GS]>*((<TD>)|(<RD>))((.+L)|(L)|.*[OB])
    2. Reflections and Specular through Refractions
    Code:
    C<T[GS]>*<R[GS]>((.+L)|(L)|.*[OB])
    EDIT: FYI, seems like the difference in result comes from STD. I've logged the issue (internal bug-tracker id: VMAX-13539) for dev investigation.
      I'll give that a try, thank you!
      www.DanielBuck.net - www.My46Willys.com - www.33Chevy.net - www.DNSFail.com
        oooh, that seems to work! thanks hermit.crab I'll try it on some more complicated scenes next, but at least on my simple test scenes it works perfectly
