Originally posted by seq
View Post
VRAY 4 MAYA SHADERLIBRARY - Version 1.1.1 including Videotutorials released!
always curious...
Originally posted by seq View Postany fix for the 2011 QT issue? Would be nice to use Bazuka's materials with the script.
yes, i am about to fix this...this will be done shortly after christmas...maxwell support is comming as well...even if it has its own shaderlibrary...
stay tuned!
OliOLIVER MARKOWSKI - Head of 3D at RISE | Visual Effects Studios
New Version online!
check out the changelog and readme below!
http://fullblownimages.com/download/...derLibrary.rar
http://fullblownimages.com/download/...erLibrary.html
Please test this and send me an email as soon as u encouter a bug. I hope i can post this on cgtalk too as soon as it is stable. So maybe u could test MR or maxwell aswell.
cheers and happy new year to every1 !
Oli
Code:Changes in Version 1.7.1 [CHANGE] VERY IMPORTANT!!!! Since Maya 2011 has display problems with the thumbnails i needed to change the preview format to PNG. I am very sorry for the hassle that is caused by autodesk, but u need to convert all *.ma.jpg and *.mb.jpg in your library to *.ma.png or *.mb.png respectivly This can be easily done by using XnView's batch conversion tool. If you still see artifacts in some thumbs you need to "refresh preview" by right- clicking on the image. [NEW] first paid feature for PX3D Hamburg - maxwell integration - if anyone else needs special features please contact me...this is cheap since it also goes to the community [NEW] HTML docs ;) [NEW] renderer dropdown [FIX] minor UI redesigns [REMOVED] removed "ignore version" for updating of shader previews...updating thumbnails of shaders from newer versions is not supported anymore (maxwell issue) [HINT] if you need to import shaders that were saved by newer maya versions you need to open a scene with "ignore version" ON and the u can also import with that option...
Hi Oli,
I downloaded the new version but I there appears to be something wrong.
When I open the library I no longer see any of the preview images of the shaders. Also I only get the Import button and no Refresh Prieview button etc.
See attacment.
I am using 2011 Advantage Pack.
The preview shader library version was working fine. Not sure what issue is??
Thanks,
Richard
Did you do that?
Originally posted by seq View PostDid you do that?that would also be my question....
also the missing buttons have moved to a right-click popup menu....try it....
cheers
Originally posted by chuckie7413 View Posthey guys. Yeah I changed them to png and this is the outcome. I changed them back to jpg but still blank
BTW: jpg is not supported anymore at allOLIVER MARKOWSKI - Head of 3D at RISE | Visual Effects Studios
Hey Oli,
Only just had time to jump back and look at this problem but I am still having issues. The conversion did not get messed up. The converted png files open fine in any image editing app.
I have an issue at the moment with vray not rendering via batch in maya so that is preventing me from doing the "refresh preview" as well.
Will get back to you once I get the render thing sorted.
Best,
Rich
Hey again,
Ok so I resolved my maya batch render issue. Was dodgy preferences folder.
However this has not solved the blank shader thumbnails.
Another problem is when rendering the "refresh preview"
It appears it is trying to load and render a preview file that does not exist.
Code:Error: File not found.: Error: Cannot load scene "C:/Documents and Settings/Administrator/My Documents/maya/2011.5-x64/scripts/FBI_shaderLibrary/renderShaderPreview_vray_.ma". Please check the scene name. // Maya exited with status 209 Render -r vray -preRender "source FBI_shaderLibrary;FBI_generateShaderPreview(\"O:/vray_shader_library/free_shaders//Animal/Croc_Skin_VRayMtl8SG.1.mb\")" -proj "C:/Documents and Settings/Administrator/My Documents/maya/2011.5-x64/scripts/\FBI_shaderLibrary" "C:/Documents and Settings/Administrator/My Documents/maya/2011.5-x64/scripts/FBI_shaderLibrary/renderShaderPreview_vray_.ma"
The refresh preview script seems to be just using renderShaderPreview_vray_.ma Looks like it is trying to get the version number but can't.
Could all the problems I am having with the library be that I am using Maya 2011 Subscription Advantage pack? The folder names are very different to previous maya installs.
Cheers,
Rich
It's definitely the SAP... EDIT:seems not to be the case....damn it! I am looking deeper into it...
Can you(or anyone with SAP) enter the following inside the MEL command line and post the result here:
Code:about -v;
Last edited by ultrasonic; 18-01-2011, 05:37 AM.OLIVER MARKOWSKI - Head of 3D at RISE | Visual Effects Studios
