Object select render element in vray 2.0 maya?
  • Object select render element in vray 2.0 maya?
    Is there an equivalent in vray maya for max's object select RE?
    No.
    But it will be better if we can connect some objects to all render elements (diffuse, spec, or other), to render just these objects.
    www.deex.info
      Not for the moment, although it is on the "to do" list.
        cool thx for the info.
        Originally posted by bigbossfr View Post
        No.
        i agree, it would also be great if those objects could have mattes built into the passes for the objects you dont want in the element. kind of like material id etc
          What's max's object select RE?
          How does it differ from object ID/matte pass/Render ID?
          Maya 2020/2022
          Win 10x64
          Vray 5
            VRayObjectSelect render element (V-Ray for 3ds Max) allows to extract objects with specific IDs into a separate element. It actually renders the image (shadows, highlights etc.) instead of just creating a mask as the other RE. When used in "Normal" mode VRayObjectSelect is similar to VRayMtlSelect.
            BR,
            Marta Kruneva
            Technical Support representative
            ChaosGroup
            Technical Support
            Chaos Group
              is there a way to render the object select now in maya... i cant find it..?
                It is implemented in the 3.0 nightlies, as it was introduced somewhat recently. If you don't have access to those, you can either send an email to support@chaosgroup.com or wait for the next service pack.
                Alex Yolov
                Product Manager
                V-Ray for Maya, Chaos Player
                www.chaos.com
