Is there an equivalent in vray maya for max's object select RE?
Object select render element in vray 2.0 maya?
No.
But it will be better if we can connect some objects to all render elements (diffuse, spec, or other), to render just these objects.
cool thx for the info.
VRayObjectSelect render element (V-Ray for 3ds Max) allows to extract objects with specific IDs into a separate element. It actually renders the image (shadows, highlights etc.) instead of just creating a mask as the other RE. When used in "Normal" mode VRayObjectSelect is similar to VRayMtlSelect.
BR,
Marta Kruneva
Technical Support representative
ChaosGroupTechnical Support
Chaos Group
It is implemented in the 3.0 nightlies, as it was introduced somewhat recently. If you don't have access to those, you can either send an email to support@chaosgroup.com or wait for the next service pack.
