Nightly Build Hairshader #3
  • #16
    Originally posted by Aquazum View Post
    create from vray-plugin->Shader->Hair
    create mayaHair and add vray attribute HairShader to the hairSystemShape
    connect the created BRDFHair to the HairShader Attribute
    play with it =)
    There is an even easier way:
    1. Select the hairSystemShape node in the Attribute editor
    2. Attributes -> V-Ray -> Hair shader
    3. Goto the Extra V-Ray Attributes and click the checker icon
    4. Then select the V-Ray Mtl Hair 3
    V-Ray developer
    • #17
      In order to accelerate self shadowing of Hair, VRayShadowMap is recommended,
      but is VRayShadowMap implemented in VRayMaya?
      OakCorp Japan - Yuji Yamauchi
      oakcorp.net
      v-ray.jp
      • #18
        For the moment - no.
        • #19
          vlado, btw did u maybe got my email? about the falloff think i asked?
          cheers
          • #20
            Thank you for the new hair shaders!
            Apart from the shadowmap are there any recommended work flows for rendering hair?
            I have read that some people have had success using photon mapping, but I wonder if there is any specific optimizations made in the hair shader that we can use to reduce flicker and rendering time.
            Best,
            Leo
            • #21
              Yes, but I did not quite follow how to wire the nodes together? Can you maybe send me a scene?
              • #22
                Unfortunately interpolated GI solutions tend not to work too well because the fine details in the hair add a lot of flickering. It might be better to use brute force + light cache + light cache retrace. It was not that slow in my tests.
                • #23
                  Thank you for the quick answer Vlado.
                  Regards,
                  Leo
                  • #24
                    connect the created BRDFHair to the HairShader Attribute"
                    How do you connect the nodes in order to add vrayHair to the hair system ?
                    www.bernhardrieder.com
                    rieder.bernhard@gmail.com
                    • #25
                      There is just the VRayHair3 material, which you can connect to an existing Maya Hair shape.
