How to use vray commands in python?
  • How to use vray commands in python?
    Is there an equivalent of mel.eval("vray objectProperties add_single VRayDisplacement") but in clean python code?
    ...for example:
    import vray.utils as vr
    myVrayDisplNode = vr.create("VrayDisplacement", add_single=True)
    I noticed this crashes Maya:
    myVrayDisplNode = vr.create("VrayDisplacement", "thisWouldProbablyBeTheNameOfTheCreatedNode")
    Best Regards,
    Fredrik
    No unfortunately. We only have the MEL commands.
    The vrayDisplacement node is a Maya node, not a V-Ray plugin, so this won't work. In the V-Ray scene, displacement is translated in a completely different way. The crash itself should be fixed for newer builds, but don't expect this command to do anything meaningful.
      Ok, thank you.
      Best Regards,
      Fredrik
        So I presume this won't work either?
        Code:
        vr.create("texture", "ColorCorrection")
        Is there currently any way to create this texture via either Python or MEL?
        Best Regards,
        Fredrik
          This code works only in the post translate callback.
          The mel code for creating such texture is something like:
          Code:
          vrayCreateNodeFromDll("tex", "texture", "ColorCorrect", 2);
          V-Ray developer
            Ah, many thanks!
            Best Regards,
            Fredrik
