How to let Scene Bump affect AO (extratex with VRayDirt) in one rendering? (beauty + AO)
How to let Scene Bump affect AO in one rendering?
Hmm, good question. I don't think there is a way to do it right now - perhaps we would need to add a bump slot to VRayDirt; or alternatively, a bump texture that can be used to apply the bump before calculating other textures. Which one do you prefer?
This would be very helpful
@Vlado - with option 2, would this be a new texture node which we apply into the bump slot of our shaders ? BitmapTexture > "NewNode" > BumpSlot ? So would it work for a standard render as well (same as bumps look right now) as well as an AO render (either a render layer override or an ExtraTex) ?
I usually assign (AO) render-layer override with vRayDirt into a Light material as a material override , so in the case of option 1, if I have many materials assigned to various geo objects - would I have to assign a VRayDirt with the (related) bump map (into its shader) to every geo object ?Last edited by ashishdani; 15-01-2015, 03:57 PM.
Originally posted by vlado View PostHmm, good question. I don't think there is a way to do it right now - perhaps we would need to add a bump slot to VRayDirt; or alternatively, a bump texture that can be used to apply the bump before calculating other textures. Which one do you prefer?
And would that slow down the render much?Last edited by freedomfries; 23-01-2015, 01:02 PM.
