Normal maps dont work with UVWRandomiser
  • Normal maps dont work with UVWRandomiser
    Hi Devs,
    Much like the issue with vray triplaner and normal maps documented here
    https://forums.chaosgroup.com/forum/...al-map-problem
    three is a similar issue with UVWrandomiser and normal maps. See attachment. the random rotation of the normal map effects the position of the highlight incorrectly
    Click image for larger version  Name:	UVW issue.jpg Views:	0 Size:	157.6 KB ID:	1119450
    Maybe its a miss use of normal maps or the overall normal map implimentation from Vray can be improved
    Your thoughts on this would be greatly appreciated, scene attached for your conveinance
    thanks
    matt
    Just so you know, we're investigating the matter. I'll write back with more information.
      Good to here. Thanks matt
        We've logged the issue (internal bug-tracker id: VMAYA-10551) for developer investigation.
