USD Parent Scope no materials.
  • USD Parent Scope no materials.
    If i export to USD with a Parent Scope i cant get materials to render.
    Is there a known issue?
    https://youtu.be/iSpcaa-7HvM
    Maya2023
    USD 0.19
    Vray 6.002
    https://linktr.ee/cg_oglu
    Ryzen 5950, Geforce 3060, 128GB ram
    Looks like if i use parent scope the Looks does not go under the flower geo.
    Arnold is doing the same but can render the data.
    Click image for larger version  Name:	ps.jpg Views:	0 Size:	16.7 KB ID:	1159492
      Hi oglu,
      In theory, the hierarchy shouldn't make any difference. The USD graph/file should define a material binding for the geo and it should just work.
      Can you get me the USD file and a Maya scene with the Bifrost graph for this? (I'm assuming this is Bifrost after watching the video. The download link gets me a json that probably needs your new custom bifrost node?)
      Alex Yolov
      Product Manager
      V-Ray for Maya, Chaos Player
      www.chaos.com
        In pure maya its the same. If you export with a parent scope and create a new USD stage with maya it wont render the material.
          Reinstalled Maya and USD now its working. Im getting more and more confused with USD.
          Nothing to see.
            https://youtu.be/6MVQf28b1cM
              Just in case i uploaded the flower asset on the Bifrost Discord here.
              https://discord.com/channels/8722602...18539103957012
                If your asset uses textures with relative paths, you'll need to change the working directory to the root of the relative path. Maybe this was the problem?
                If you have the usd files as ascii (or the maya scene that created the USD graph) it would be easier to tell what was happening.
                Good to know it's working, but I don't really have an idea why it wasn't working before re-installing. If it was just the textures that didn't load - it might be an issue with relative paths.
                Alex Yolov
                Product Manager
                www.chaos.com
                  I cant attach the scene here its to big. But i uploaded the files on discord link above.
                    I downloaded it, but the Maya scene did not contain the Bifrost Graph.
                    Where is the USD originating from?
                    Alex Yolov
                    Product Manager
                    www.chaos.com
                      I exported it from Maya. Just Export selected.
                      I do an other upload with the Bifrost file on Discord.
