Object Properties with Matte Surface generating different render element between vrscene and maya geo
  • Object Properties with Matte Surface generating different render element between vrscene and maya geo
    Hey there,
    I was using VRayObjectProperties to create Matte surface for my render layers, and I noticed that GI and Lighting pass are not black on my matte surface.
    I quickly create a simple scene, and realize that this only happen when using vrayscene as matte surface. If my matte surface is a Maya Geo, it's all black in all render elements.
    I am using Maya 2023 and VRay v6.00.03, is there something I need to check to make matte surface not showing in GI pass while using vrscene?
    This a simple scene I created with a cube and a ground plane. The ground plane is in VRayProperties set with Matte Surface on
ID:	1188954 Click image for larger version
    you can see on the left , a Maya geo plane, it's all black in GI pass,
    But on the right, it produces GI on matte surface using vrscene( I tried loading both vrscene and usd file).
    same thing happened to Lighing pass
    Here is my simple test file vray_objectPropertyTest_matteSurface.zip
    This issue seems to be fixed in the latest official build. Update and try again.
      Thanks!
      We are in the middle of a production, so I can't just update now. But I will definitely give it a try after.
      Best,
      Han Ho
