Yeti, maya, vray no fur in render?
  • #16
    I've been testing Yeti too and it's actually quite simple and nice to use. I struggled a lot more to get Shave to render nice results.
    There are a few youtube videos that show you how to fur and groom a character, and the documentation isn't too bad really. Obviously it's a new software so it doesn't have many tutorials etc. yet. I still found it quick to get into. Learned how to get it up and running within a couple of hours.
    Super quick test:
    Took about 3-4 minutes on an i7-3930k with GI BF+LC and VrayHairMtl3.
    /Bard
    www.hellobard.com
    Norwegian Broadcasting Corporation (NRK) - Motion graphics artist
    • #17
      I have Yeti installed in Maya & it works But I cannot for the life of me get it to render in Vray!
      I have done as the yeti installation guides say in regards to environmental Variables & all the plugins load up OK in maya. but it wont render.
      does anyone who has this working have a checklist of what to do to make it render?
      Thanks
      Chris
      • #18
        Do you get any warnings or errors when you render?
        • #19
          no. but im at home testing this & only have a demo of vray. the guys at peregrin labs think maybe the demo wont let me use custom plugins/procedurals
          • #20
            The custom plugins should work, there is no limitation, but I'm not quite sure if it's not something else in the demo.
            • #21
              OK, how can i test that theory?
              • #22
                I've tried to test Yeti with the V-Ray Demo. Unfortunately it didn't work for me as well.
                BTW, Yeti is working very well with V-Ray ADV.
                I hope it helps you.
                Best Regards,
                Sangho Jung.
                • #23
                  Ok, thanks for the confirmation - will check it out.
                  • #24
                    would that be something from the Yeti end or Chaos end ?
                    • #25
                      Probably something in V-Ray... the demo might be specifically coded to load only the standard V-Ray plugins - I have to check. In any case, we can get you a full evaluation license if you need it.
                      • #26
                        Hello!
                        I'm thinking about migrating from max to maya and I want to test vray with yeti but with my demo vray installed I can“t see the hair in the render.
                        I have maya 2017, yeti 2.5 and vray 3.5 demo
                        Is the problem with yeti and vray demo stil there or could be a installation problem? (I think I did all the evironment variables stuff well...)
                        www.gaell.com
                        • #27
                          in pre render mel is there a pgYetiVRayPreRender line input?
                          Dmitry Vinnik
                          Silhouette Images Inc.
                          ShowReel:
                          • #28
                            Yes it is!
                            I've attached captures of my maya settings and environment variables.
                            So the vray demo should render fine yeti hairs?
                            www.gaell.com
                            • #29
                              Unfortunately, the demo version of V-Ray doesn't support Yeti. I'll make a note to discuss adding this ability to the demo.
                              Alex Yolov
                              Product Manager
                              V-Ray for Maya, Chaos Player
                              www.chaos.com
                              • #30
                                Ok, that make sense but I really looking in migrating from max to maya but I need to test yeti first. Is there any possibility to have a copy of vray for maya 2017 that supports yeti just for testing?
                                Thanks
                                www.gaell.com
