Env reflections not working with refraction
    Originally posted by svetlozar_draganov View Post
    Another similar approach like the one I mentioned earlier would be to wrap the entire scene into a sphere and attach the texture into self-illumination-slot of that sphere. Then if you create a local-override and replace reflection material with a pure black material you will have the same behavior as with the dome-light. With this method you won't have to override every single material, only sphere-material should be overwritten.
    Example Scene=>[ATTACH]18661[/ATTACH]
    Thanks for this. This brings up a feature request:
    It would be awesome if there was a vray infininitly-distant sphere geo, similar to the vray plane.
      Originally posted by DADAL View Post
      Then simply do not use IBL and just put a texture in to your env refl/refr overrides and that should do it.
      Or just create a big sphere, set pri vis off cast/recieve shadow off and apply vraylightmrl with texture in it.
      I'm not sure but wsnt that explained early in topic?
      As I explained earlier, both of these approaches do not work because the produce errors in comp. You can see an illustration of the problem in post #6 of this thread. The dome light approach solves this, as does the approach Svetlozar outlined using a sphere with a refraction override in post #7.
        In post 6 you mean that texture behind sphere? I assumed that it was wrongly put texture in to ur background slot. Keep background slot empty/black and it should work no?
        Oh nvm scratch that I'm wrong.
        So basically you want reflections/refractions but you dont want to see throught the glass the ibl texture right? I think I had a good solution for it b4 leme see if I can remember it
        Ok we have the same issue. Nvm got no better way of doing it than svetlozar_draganov , sorry @_@
