ok, i have a hardware setup as follows :-
pc win 7 (main machine) and a macbook pro (acting as vray slave) - maya 2012 - V-Ray: V-Ray for Maya version 2.40.02 from May 14 2014, 15:55:48
[2014/Jul/16|14:07:47] V-Ray: V-Ray core version is 2.00.02
I'm working on an under water scene, which renders just fine when rendering a single frame in VFB, but when I set of a batch render using a .bat file i get these discrepancies between the render regions , please see images ,
on the batch render the first few frame that are output seem ok but then after that the discrepancies start to appear.
the caustics are false , i'm using a spotlight with an image sequence applied, the image sequence is only 16 frames and repeated throughout the animation. (seamlessly tiled image sequence)
any help would be appreciated
regards
ignuf
regards
ignuf
