vray 3 maya - // Error: Could not obtain an interface license (-200)!
  • vray 3 maya - // Error: Could not obtain an interface license (-200)!
    hi all
    ok, installed vray 3 on new computer, ( along with maya 2014,2015, 2016) installed the WIBU drivers and license servers but keep getting "// Error: Could not obtain an interface license (-200)!" checked the status of the server (http://***.***.*.**:30304/getstatus) and all seems good there , so why can't maya find the interface license ?
    please help - win 7 workstation
    thanks and regards
    ignuf
    PS , could it be due to the fact the system only has usb 3 ports ?? the support documentation seems to prefer usb 2 ports.
    update :
    if i use the dongle on an older computer (which only has usb 2 ports) which is on the same network , maya seems to find the license... does this point to the use of the usb 3 ports ?
      Please make sure that the License Server information is set correctly. The Primary server should point to the machine where the dongle is plugged.
      If that is the local machine you could also use:
      localhost
      or
      127.0.0.1
      The dongle should work fine on USB3.0 ports but in case you have USB2.0 port on the new machine try to plug the dongle there and let us know if there is any difference.
        hi Svetlozar,
        thanks for the reply ,
        silly me, as you suspected, I had mistyped the the IP address ,
        thanks again and regards
        ignuf
          Glad to hear that everything is fine now
