Atmospheric Effects
  • Atmospheric Effects
    Hi, if anybody could help me how to achieve that fog effect in vray? i tried aerial perspective, enviorment fog etc but all seems so flat. am i missing something or what should i do? use 3d texture in somewhere? ( i dont know hot to use them in maya )
    V-Ray Environment Fog should be able to generate similar result.
    Can you show is the result you've got so far?
      You could also use a gizmo with a falloff radius to contain the fog in certain areas only.
      https://docs.chaosgroup.com/display/...ple:Gizmonodes
      V-Ray for Maya dev team lead
        my main problem is i dont know how to use 3d textures in vray enviroenment volume to make variations in the fog or fade it out slowly to certain direction like in the example picture, so my fog looks so much uniform. i know it's a maya question more than a vray question but couldnt find any resources about that. if you can direct me about that i would be very greateful.
          Photoshop. You will spend days trying to figure out how to render this... If it is a still spend 30 minutes in Photoshop and you will be done.
            ok... what should i search for to how to do that in photoshop?
              At least put a bit of effort into searching...
              https://www.google.com/search?source...7j0l5.6923j0j7
                i cant if i dont know what to search exacly. thank you.
                  output a zdepth pass and use it in paint or comp program to create a fog effect.
                  __________________________________________
                  www.strob.net
                  Explosion & smoke I did with PhoenixFD
                  Little Antman
                  See Iron Baby and other of my models on Turbosquid!
                  Some RnD involving PhoenixFD
