VRay frame buffer disappearing
  • VRay frame buffer disappearing
    The VRay frame buffer is STILL disappearing - we've all encountered this on occasion before, but usually an edit of the windowPrefs.mel usually brings it back.
    I've now hit a show-stopper version of this problem. No fix known to me works.
    If I click the 'Show V-Ray VFB' button on an empty scene, the frame buffer shows up. Great. As soon as I hit the render button the VFB disappears completely. Not visible in windows. Unrecoverable.
    Things I have tried:
    - uninstalled VRay completely. Restart. Install VRay again. Restart.
    - removed ALL maya preferences.
    - edited the windowPrefs.mel file.
    - Windows + arrow keys etc.
    Just to reiterate - the VFB can not be seen in the alt-tab menu, nor does it show up as one of the Maya windows. For all intents and purposes it is literally gone.
    I'm not really sure what else I can try.
    For what it's worth, once the vray buffer has gone, when I close maya it writes to the windowPrefs.mel file: -topLeftCorner 487 -32768. Is this a clue as to what is going on?
    Cheers,
    Geoff
    Can use this mel one-liner, to Zero out the vfbSettings array in your ma file, which is where the problem lies.
    setAttr "vraySettings.vfbSettingsArr" -type Int32Array 0;
    When you do the above don't render, just save, close and re-open maya. For some reason maximizing & minimizing maya then trying to open the vfb brought the window back, lots of kung-fu there but I got it back.
      What about all other tricks to bring VFB back shared here:
      http://forums.chaosgroup.com/showthr...-the-V-Ray-VFB
