how to get rid of specular highlights?
  • how to get rid of specular highlights?
    Hi guys, I need some help please.
    I have this floor with bad specular highlights. In Modo I can lower the specular effect of the light source to 10% or so and it will look right. This technique does not work in vray. How can I get rid of it?
    I made a group of the lights and added an item shader to it, removed "visible to reflections rays" but still it reflects.
    I used point lights with a radius of 25mm for the light sources.Click image for larger version
    If you are using a V-Ray material, just uncheck "Lock hilight glossiness" and increase the "Hilight glossiness" until you are happy with the size of the specular hilights.
    Or you can go to the "V-Ray Light" tab for the light and unckeck "Affect Specular".
    Something that will work in both V-Ray and MODO, is to select the light material for the light and decrease its "affect specular" value.
    Edit: I didn't read your post carefully, sorry. It seems you were trying the "affect specular" option of the light material like I suggested. This option doesn't work in RT GPU at the moment, at least for point lights.
    Greetings,
    Vladimir Nedev
      Something that will work in both V-Ray and MODO, is to select the light material for the light and decrease the "affect specular" value.
      Greetings,
      Vladimir Nedev
      Thanks Vladimir
      The first 2 options work (I have started to use vray materials on everything...it just seems to work a little easier.
      As for the option to decrease the "affect specular", it does not always work. I tried this first. Sometimes it looks as if the value is completely ignored, sometimes not.
        Are you using RT GPU ?
        Greetings,
        Vladimir Nedev
          RT CPU. now I am not sure anymore....I did a lot of prelims with RT and some renders. maybe that is where the difference came in. I will need to test again to be sure
