When I get a Substance material and I start to tweak the lights, after a bit I get the "out-of-mem" message. The workaround is to use a lower texture resolution as 256x256, but the work on the model to tweak will be different from the final render.
I suspect this is a sort of "normal behaviour since I think that Vray GPU has to bake the texture to show on monitor the results of the Substance material. There's maybe a way to optimize this in the future code or we will have just to buy GPU with more VRAM? (or use the future vlink from the 2080 gpus?)
Thanks!
A.
Thanks!
A.
