V-Ray 5 keeps crashing Rhino 6
  • V-Ray 5 keeps crashing Rhino 6
    Since I've upgraded V-Ray Next for Rhino to V-Ray 5 I am having persistent crashing issues with Rhino. I spent a considerable amount of time with the people from McNeel trying to resolve this issue. Every time I open an existing file it crashes Rhino 6. If I open it a second time it seems to sometimes work and opens it. The people from McNeel asked me to disable V-Ray as a plug-in to see if the issue persisted and it didn't meaning that it is most likely V-Ray 5 that is causing the issue. The file also opened a considerable amount of time faster than when V-Ray is enabled. Is anybody else having these issues? Does anyone from ChaosGroup have any suggestions as to what may be causing this? I can go through the whole "please send us the file and error message" procedure if you'd like but it is essentially every file I am working with that does this since upgrading to V-Ray 5.
    Hi PixelPerson81
    Sorry to hear you're experiencing such issues. Can you make sure to download the latest V-Ray 5 for Rhino hotfix from here and confirm if the issue persists?
    Moreover, please do share more information regarding your OS version, CPU, GPU/driver versions as well.
    Best would be to forward us the crash dump and log files so we can have a look and investigate what may be causing this:
    • You can find them in the following locations: C:\Users\USERNAME\AppData\Roaming\Chaos Group\V-Ray for Rhinoceros\vrayneui
    You can forward them through our online Contact Form - just make sure to mention this thread in the email. Thanks!
    Nikoleta Garkova | chaos.com
      I have similar issue with Rhino 7 every time I try to render, rendering window pops out but when I click back on rhino it crashes. It happens 100% of time. I've installed newest Rhino 7 version and hotfix You've mentioned.
        Hi alicja_tomaszewska
        Can you please answer the same questions as listed in my post above and forward us the crash and log files so we can have a look? Much appreciated!
          nikoleta.garkova I've already sent an email to support@chaosgroup.com with packed project, I'll send others as well
            I'm not able to find any log/dmp files in locations You've provided
              I'm not either. What I do see is a file titled "telmetry.json.". Is that what I am supposed to send? I noticed Nikoleta that in the address you sent as an example it references Sketchup. I followed what you sent me thinking that it would be the same path for Rhino but I don't think the log/dmp file is there.
                It is not,
                I tried many things, update windows and graphic drivers, restarted machine many times, reinstall vray and rhino, all with the same result, as long as I run render it crashes, sometimes it renders but when I click on anything rhino crashes. Without vray 5 with native rendering engine all works fine.
                  My _SystemInfo result:
                  Rhino 7 SR1 2020-12-8 (Rhino 7, 7.1.20343.09491, Git hash:master @ 350b20978b4fcd75493212fbd3c4248983612f86)
                  License type: Komercyjna, build 2020-12-08
                  License details: Cloud Zoo
                  Windows (Physical RAM: 16Gb)
                  VersionMajorMinorServicePack failed
                  Computer platform: DESKTOP
                  Standard graphics configuration.
                  Primary display and OpenGL: NVIDIA GeForce GTX 970 (NVidia) Memory: 4GB, Driver date: 12-11-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 460.89
                  > Accelerated graphics device with 4 adapter port(s)
                  - Windows Main Display attached to adapter port #0
                  Secondary graphics devices.
                  Intel(R) HD Graphics 4600 (Intel) Memory: 2GB, Driver date: 3-30-2014 (M-D-Y).
                  > Integrated graphics device with 3 adapter port(s)
                  - There are no monitors attached to this device!
                  OpenGL Settings
                  Safe mode: Off
                  Use accelerated hardware modes: On
                  Redraw scene when viewports are exposed: On
                  Anti-alias mode: 4x
                  Mip Map Filtering: Linear
                  Anisotropic Filtering Mode: High
                  Vendor Name: NVIDIA Corporation
                  Render version: 4.6
                  Shading Language: 4.60 NVIDIA
                  Driver Date: 12-11-2020
                  Driver Version: 27.21.14.6089
                  Maximum Texture size: 16384 x 16384
                  Z-Buffer depth: 24 bits
                  Maximum Viewport size: 16384 x 16384
                  Total Video Memory: 4 GB
                  Rhino plugins that do not ship with Rhino
                  C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp "V-Ray for Rhino"
                  Rhino plugins that ship with Rhino
                  C:\Program Files\Rhino 7\Plug-ins\Commands.rhp "Commands" 7.1.20343.9491
                  C:\Program Files\Rhino 7\Plug-ins\rdk.rhp "Renderer Development Kit"
                  C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 7.1.20343.9491
                  C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 7.1.20343.9491
                  C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp "Renderer Development Kit UI"
                  C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp "Snapshots"
                  C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp "RhinoCycles" 7.1.20343.9491
                  C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 7.1.20343.9491
                  C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
                  C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp "Displacement"
                    System Info:
                    Rhino 6 SR32 2020-12-5 (Rhino 6, 6.32.20340.21001, Git hash:master @ f0da95af49009959d0100568acb11aea288bcea0)
                    License type: Commercial, build 2020-12-05
                    License details: Cloud Zoo. In use by: Lululemon ()
                    Windows 10.0.0 SR0.0 or greater (Physical RAM: 64Gb)
                    Machine name: DESKTOP-DAR92LG
                    Primary display and OpenGL: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 12-11-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 460.89
                    - Secondary monitor attached to adapter port #0
                    - Windows Main Display attached to adapter port #1
                    OpenGL Settings
                    Safe mode: Off
                    Anti-alias mode: 8x
                    Render version: 4.6
                    Maximum Texture size: 32768 x 32768
                    Maximum Viewport size: 32768 x 32768
                    Total Video Memory: 11 GB
                    Rhino plugins
                    C:\Program Files\Rhino 6\Plug-ins\Commands.rhp "Commands" 6.32.20340.21001
                    C:\Program Files\Rhino 6\Plug-ins\rdk.rhp "Renderer Development Kit"
                    C:\Program Files\Rhino 6\Plug-ins\RhinoRender.rhp "Rhino Render"
                    C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 6.32.20340.21001
                    C:\Program Files\Rhino 6\Plug-ins\rdk_ui.rhp "Renderer Development Kit UI"
                    C:\Users\Joël Legault\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.12.17.906\PanelingTools.rhp "PanelingTools"
                    C:\Program Files\Rhino 6\Plug-ins\NamedSnapshots.rhp "Snapshots"
                    C:\Users\Joël Legault\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\Yulio for Rhino (893a6721-40f4-45a9-8d9d-96ca37101d3c)\2018.4.3.945\YulioForRhino.rhp "Yulio for Rhino"
                    C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp "RhinoCycles" 6.32.20340.21001
                    C:\Users\Joël Legault\AppData\Local\Programs\Enscape\Bin64\Ensca pe.Rhino6.Plugin.dll "Enscape.Rhino6.Plugin" 0.0.20311.1317
                    C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 6.32.20340.21001
                    C:\Program Files\Rhino 6\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
                    C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp "V-Ray for Rhino"
                    C:\Program Files\Rhino 6\Plug-ins\Displacement.rhp "Displacement"
                      Alicja how are you finding Rhino 7? Is it worth the upgrade. I know you can do subdivision modelling with it but overall is it worth it? I do find that Rhino 6 seems to be the buggiest version McNeel has ever released. I was hoping that a lot of this would be resolved with the newer version.
                        I don't know how I find Rhino 7 because all my problems started just after I bought and installed it + Vray 5. Previously I was working on Rhino 5.
                          Hi guys, apologies - I'll edit my original post to avoid any confusion.
                          Rhino log files can be found at C:\Users\USERNAME\AppData\Roaming\Chaos Group\V-Ray for Rhinoceros\vrayneui - should be named vray-neui.<some-number>.log.
                          If you get a crash, Rhino will automatically generate a crash dump file (.dmp) which is usually saved on your desktop.
                          As mentioned, you can forward the files through our online Contact Form.
                            Dear nikoleta.garkova I've sent message to vrayrhino@chaosgroup.com with detailed description of my problem ( I was asked to use this email by my retailer). Now I've forwarded it to support@chaosgroup.com. I really count on fast response and contact as it hurts my business. I can't do my job without vray5 working with rhino 7.
                            • #15
                              I sent the log file Nikoleta to the link you told me to. Rhino does crash the first time you try opening a file (I tried it on another computer as well with the same result) but it does not produce the .dmp file. I hope you can help us as the people at McNeel are totally useless.
