Hello nikoleta.garkova I've sent several emails with problem description to support email. Please contact me, it's really URGENT !
V-Ray 5 keeps crashing Rhino 6
Hi alicja_tomaszewska
Would it be possible to share the support ticket number so I can check in our system (you should've received one by email)? Thanks!Nikoleta Garkova | chaos.com
I too am having problems with Vray5 & Rhino 7 freezing.
It's random, and frustrating.
Here is my post from Rhino discourse:
Rhino 7 sr1 & Vray 5 hotfix1.
I’m getting random system freezes typically right after starting a production render (rtx, cuda or cpu).
I wait a few minutes, then hit reset button, reboot, back to work.
Happens with new files created in R7 & Vray5, or updating older files (R7 & Vray next).
Doesn’t matter if its a small/simple file (no fur), or larger complex file, sometimes 1 freeze per day, other times a few in a row then it goes away.
Sometimes first render freezes, other times it’s after working several hours and successfully rendering dozens of frames.
The only action that may be triggering this is closing current Rhino file, opening another to use copy/paste, then back to original Rhino file.
During the fall I evaluated with Rhino6 & Vray next, seemed stable. But I was doing simpler things.
Glenn
Rhino 7 SR1 2020-12-8 (Rhino 7, 7.1.20343.09491, Git hash:master @ 350b20978b4fcd75493212fbd3c4248983612f86)
License type: Commercial, build 2020-12-08
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Standard graphics configuration.
Primary display and OpenGL: NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 12-11-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 460.89
> Accelerated graphics device with 4 adapter port(s)
- Windows Main Display attached to adapter port #0
OpenGL Settings
Safe mode: Off
Use accelerated hardware modes: On
Redraw scene when viewports are exposed: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Anisotropic Filtering Mode: High
Vendor Name: NVIDIA Corporation
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-11-2020
Driver Version: 27.21.14.6089
Maximum Texture size: 32768 x 32768
Z-Buffer depth: 24 bits
Maximum Viewport size: 32768 x 32768
Total Video Memory: 8 GB
Rhino plugins that do not ship with Rhino
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
Rhino plugins that ship with Rhino
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 7\Plug-ins\Calc.rhp “Calc”
I was away during the holidays nikoleta.garkova . I emailed you the Rhino Crash file you requested. The issue seems to be persisting. alicja_tomaszewska and glennco have you noticed if it is files that were worked on with previous versions of V-Ray (ie. V-Ray Next) when the crashing happens? For me it seems as though whenever I am opening a file were previous versions of V-Ray were used it crashes. It always gives the message that the file will be "upgraded to the most recent version of V-Ray", runs for a bit, and then crashes. I'm curious if there is an issue the way that V-Ray 5 attempts to read older files.
- Likes 1
Thanks PixelPerson81 for providing the files over;
I've managed to find your ticket, alicja_tomaszewska, you should have a reply by now;
glennco, the issue you are describing seems a bit different. Would it be possible to provide more details regarding when exactly are the freezes occurring; from what I understand that would be during rendering - are you getting any warnings/error messages in the V-Ray Progress Window? Are you using any third-party plugins and have you tried disabling them prior rendering with V-Ray? Would it be possible to forward the log files so we can check if they can point to anything specific? You can find them in C:\Users\USERNAME\AppData\Roaming\Chaos Group\V-Ray for Rhinoceros\vrayneuiNikoleta Garkova | chaos.com
Hi PixelPerson81 - our devs are looking at this as we speak; the crashes have been reported and logged in our internal system and it appears they were not related to our plugin - can you try with Rhino 6 version 6.29.20238.11501? Do send the dump files again if you experience another crash. I've followed up with in our email conversation with the same request. Thanks!Nikoleta Garkova | chaos.com
There is a (good) chance the freeze issue is driver related.
Studio driver 460.89 12/15/2020
Yesterday, my system froze when I wasn't using Rhino (or Vray), in fact i wasn't doing anything.
I also notice when the freeze happens Nvidia Geforce experience (icon) disappears from Windows taskbar (lower right side).
Quick google search on 460.89 shows other users having similar problems.
Thanks,
Glenn
Originally posted by tsponti View PostHi,
did someone find a solution to this problem because I have the same issue and this is really boring.
thanks for your answer.
Apologies for the late reply!
If you have not yet reached out to our support team directly, please use https://support.chaos.com/hc/en-us/requests/new to report your issue and provide us with info about the version of V-Ray you currently use as well as your hardware and GPU drivers version. This way my colleagues will be able to assist you directly.
Kind regards,
PeterPeter Chaushev
Let's keep in touch
Peter.Chaushev
i had several emails with them, with Diana Milenova to be precise, but they never find a solution....
so I don't know what to do to fix this problem.
any idea?
thanks a lot.
regards,
thomas
Will review the details of your correspondence and together with my colleagues from our support team will get back to you as soon as possible. Thank you for your patience!Peter Chaushev
Let's keep in touch
