Rendered Viewport Transparency
  • Rendered Viewport Transparency
    This probably goes along with my rendered viewport bump map post.
    If I use a basic material with transparency, it is displayed correctly in the rendered viewport, but if I use a vismat with transparency it does not show any transparency in the rendered viewport. I think it should, would be helpful when setting up view angles through windows.
    Thanks,
    Craig
    Re: Rendered Viewport Transparency
    Yeah I think that goes back to the other issue as well. we have fixed the bump map one on our internal builds but I'll double-check that there isn't any transparency issues.
    Joe Bacigalupa
    Developer
    Chaos Group
      I think I misread this originally. So what would you want the basic material to match up as far as transparency goes? I believe we make the refraction layer get treated as transparency at the moment. But did you want it to use something else? Diffuse transparency?
      Joe Bacigalupa
      Developer
      Chaos Group
        Yes, diffuse transparency, I would think.
        My architectural glass materials never use refractive layers anyway.
          Hmm - I see. Ok I suppose we could find a way of combining the two or using one instead of the other. I have to be middle-of-the-road with this stuff because some people do only use "real" glass instead of diffuse transparency. I'm sure we can figure something out.
          Joe Bacigalupa
          Developer
          Chaos Group
