How do I duplicate a material - keeping the linked textures within the material linked but removing the link to the textures in the material I've just duplicated? I keep editing duplicated materials only to find out much later that my original material's changed as well!
Duplicating a material with globalized textures - maintian links within material but not globally?
Ok, a bit more digging, and I realize there is a difference between globalized textures and linked instances within a single material. Somehow I must have pasted an instance inside another material which globalizes that texture. Once a texture is globalized is there no easy way un-globalize it!? i.e. remove the globalized link but maintain the intra-material linked instances?
Hello Paul, if you unwrap the material see you can either see the texture symbol & name, or you can see an arrow in front of it. Arrow = linked independent texture and all changes propagate. Without arrow = all independent.
There's also a bug I've reported earlier that duplicating Blend material keeps it connected to the original, but Chaos haven't managed to reproduce it.
https://forums.chaos.com/forum/v-ray...ll-interlinked
Jonas
